As I understand it this steel cover acts as a thrust surface for a non insert bearing int shaft in an early case.Please correct me if a mag(later68on) cover is usable in this application.Let me know what youve got. Thanks! Steve
Steve, I have one, if you can give me til X-mas to send it $25. You can use a mag one but you will be replacing it once the intermediate shaft grinds a circle into it - not good.
Hi Scott, I was just going to pm you to see if you had one.Ill take it ,is your paypal up and running? let me know where to send acheck if not.. Steve
Does anyone have one they are ready to send out now,I actually want to have my parts all together before the 20th of dec. Thx Steve
You could always make one out of some steel stock if you really need it right away - A simple trace, cut and drill using a mag vesion as a template would work (or get fancy and have a local shop laser cut one for you).
Regads,
Andrew M
Found a couple ;) Steve
