It looks pretty much like a (very good to me) 3d rendering! Everythings looks so neat.
Olivier.
Duel SWB heater controls.
Chris
Silver buttons everywhere…including the 300km/h speedometer…
Attachment 328990
Hand painted:
I did a little interior decorating. I went to a more suportive drivers upper. I'll probably show the car with the wood wheel and shifter and drive it with the other wheel and stock type 5 speed shifter.
Chris
Chris, I'm curious, how did you attach the heater cable to two levers?
I'm not sure you'd call this satanic but.....
Door panels and door furniture work in progress;
Panels are high density foam with a layer of fiberglass each side. Will be covered in embossed leather.
Door pull / armrest structure is fabricated aluminium, laser cut, folded and welded. Big tubes give access to fixings to door, and to add a bit of retro. Plan is to anodize silver. Welds will be dressed but still showing.
Top plate is double thickness of the same material as panels, glassed over to form a plank and then covered in stitched leather on foam.
Door release loop strap will come out in normal place - not through the back slot.
