anyone know where/which fuse controls the under dash a/c blower unit.
thanks
Jerry
thanks
Jerry
There is a relay in the smugglers box on factory installations. Also an additional two fuse addition to the normal fuse panel on a factory install, not sure what a Griffith install does.
thanks- I have changed the 2 fuses in the added fuse panel. I'll check the relay.
Jerry
You're welcome,,:)
