Anyone know if this lever is stock and what model it would have come from? There is a slight sideways bend low and a rearward bend high.
If threaded at top looks right for 65 with screw on 356 type mushroom knob. I think Sometime in 66 they went to sleeve mounted round knob where top of shifter is not threaded. Others can confirm
Porsche changed from threads to sleeve in 1967 , so the shifter could be an early '67 .
It is threaded, I wasn't sure if the lower sideways bend is stock or if it has been modified.
My 65 lever also has a slight lower bend.
901 box
64-mid 66 (nobody knows the cutoff)
not 67
I worked on an amazingly original '67 with a threaded shift lever , so I vote for '67 , or maybe it was an extra Porsche found . The more we learn the more we realize things are not always absolute .
Threaded shift levers were discontinued in March 67, according to Porsche.
Attachment 524145
Jon B.
Vista, CA
Thanks for the replies. After checking my 65 built 66MY 912 the shift lever looks like the one I posted, I checked my 3/30/67 built 911 SWT 500213 and while it is threaded the bend rear ward is much lower than the earlier lever. I think 304065 has it right. But it does contradict the Porsche bulletin posted by Jon B. This is a pic of the lever in the 67 SWT(original unrestored interior)
