Front Bushing Replacement
hi all,
I am in the process of scoping my Bushing Replacement project for my 1973. It is clear I need to do the rears and will going with the Rubbery Neatrix units.
I was planning on using the poly front bushes which I would machine to match the a-arms.
For the fronts I suspect the bushes were replaced by the PO when the front end suspension pan was replaced. The front bushes are easy to see and appear to be almost new (shiny, smooth pretty even). However, i am not sure how to inpsect the rears short of actually removing the A-Arm. Is it possible to inspect the rear A-arm bushes without removal? Does anyone have a picture of what a worn bush would look like when I inspect it on the car?
TIA :)
