Rear torsion bar bushings
Hi all,
I'm new to this list (I'm a 356er) but posting the following question for a buddy who has a '67 912 (SWB) with recently replaced rear torsion bar bushings. The original rubber ones were replaced with hard plastic (delrin, nylatron or ?) and the ride is now very hard and squeaky. The shop that did the work says that the original style is no longer available. The outside diameter is smaller than both 356 and later 911/912 ones but the ID is the same.
I'm thinking of turning the oversize ones down to the right diameter. Anyone have any experience with this or any alternatives?
TIA,
...Bill
Spring plate bushings 1967 911 or 912
have been waiting to check before responding to this question. My parts book only goes up to 1967. And it helps to have cars to trial fit parts. If your friend is replacing plastic bushings rubber ones should still be avalilble.
I took a set of bushings for my 1965 to the shop to verify the fit into the 1967. The change was "up to Model A" and "after model A" (The serial number change for the 911 was 305 101). Prior to the change the inner bushing had a smaller OD diameter, conical shape from 71 down to 68mm and 32mm wide. (It seems to me they also fit the 356C and has a 356 part number 644.333.131.00). The dimension of the inner bushing socket on the 1967 is larger in diameter and width than the 1965-66 at 75mm OD and 46mm wide. (ID on all are 47mm). From 1967 on both the inner and outer bushing are the same size: Porsche part number 901.333.195.00.
The ones I have were from Stoddard. If not available today, check with Performance Products for their Neatrix rubber bushings. They listed the larger outers (same as the inners from 1967 on) so you should be able to fit all up to the bonded ones - which I beleave came in 1969.
Bob
