I need an electric delivery pump that need not function. I actually only need the small cap that contains the pressure relief springs. This is the top hat shaped aluminum cover that sits at 12:00 on the pump body. Mine has corroded and now allows the seal to leak.
If anyone can help me out with this silly little part I would greatly appreciate it.
Thanks, Scott
