torsion bars, what to do.....
so, my '73 hotrod, RS clone....built-up 3.0, will spend some time on the track, but mostly used for road events.....is apart for the winter, carb work, suspension refresh....
the previous owners (at least the past 2, maybe 3) seemed to have done some upgrades, but cut some corners at times, probably to save money....
I found the right rear was sitting too low, I found a set of used SC spring plates....new torsion bar bushings, was told the t-bars were upgraded at some point in the past....I'll do the fronts next, so soon I will find out what's up there.
I found the rears are most likely sway-away solid 30mm bars, I was hoping for something a bit more exciting, hollow bars, elephant racing, I dunno....should I leave them alone, or do the upgrade while it is all apart?
Yes, the budget concerns me.
Lewis
