FS - lots of 1970 T stuff - engine, trans, interior, etc..
I have a lot of leftover and surplus parts from my recent 1970 targa restoration. I've just posted several threads on Pelican with photographs, and will refer you there to see them, along with a little more description of the various parts. Or you may feel free to email or PM me here and I can send photos directly.
Pelican threads:
2.2 engine parts
901/911 transmission parts
23mm torsion bars
interior pieces
Here's a parts list with prices:
RPM transducer/speed switch, UNTESTED - $30.00
Rear Defog relay, UNTESTED - $30.00
2.2 (66mm stroke) crank, std/std, in spec - sold
2.2 connecting rods (6) - - sold
2.2 lower valve covers (2) - $20.00/ea.
2.2 T pistons/wristpins (5) - $20.00/ea.
2.2 upper valve cover (slight corrosion, should seal) - $10.00
Beru plug wires (5) - $5.00/ea. sold
Chain tensioners (2, rebuildable) - - sold
Crossover exhaust pipe - $40.00
Cyinder to head spring gaskets (3) - - sold
Fuel pump - Bosch, UNTESTED - $40.00 sold
Intermediate gear - - sold
Intermediate shaft (core) - - sold
Intermediate shaft chain sprockets (2) - $10.00/ea.
Intermediate shaft/oil pump coupler - $10.00
MSD ballast resistor (new) - $5.00
rear tin (single large rear-most piece) - $20.00 sold pending payment
Rocker shaft expansion collars/bolts (3) - $2.00/ea.
Rocker shaft valve adjusters (3) - $2.00/ea.
Rocker shafts (5) - $4.00/ea.
Sump plate - $5.00
Throttle bracket (CIS) - $20.00
Throttle linkage (bell crank to engine) - $25.00 sold pending payment
Valve stem seals (12 new) - - sold
Collapsable oil return tubes - $20.00
Door pocket bracket - $5.00 sold
Accelerator pedal - $8.00
Basketweave vinyl for dash (new) - $15.00 sold
Headlight switch - $15.00 sold
Ignition switch - $15.00 sold
Momo steering hub, L231 (for >1973) - - sold
Dash speaker grille - $60.00 sold
23mm torsion bars - $40.00/ea.
Front sway bar block-off plates - $5.00
901/911 1/R slider - $120.00
901/911 Brake bands & stops - $5.00/ea.
911 Clutch disk (7.7mm remaining thickness) - $15.00
CV bolts & moon plates - $0.50/ea.
CV housings and bearings - $5.00/ea.
901/911 dog teeth (3) - $30.00
901/911 2/3 slider (2) - $40.00ea.
V gear set (visibly worn) - $40.00
Mike
