Has anyone found replacement rear rotors for a '67S-'68L?
Hello John,
Sebro should work. Their part number: 205839C
Regards,
Joachim
Search 944 rear rotors and see the fit and mod to use them. Sorry some of my old links are broken with the info.
Thanks guys!
John if the photos are missing from old posts, here they are.
When describing the enlarging the flat head screw holes with the use of a wood bit came across as a bid deal, it was easy.
I over drilled them and that was the caution. Look at the depth of those holes, far deeper than needed.
Thanks Bob!
