5 Attachment(s)
Had some more time to work on the car, the fixed glass is now out, front glass i just managed to push out gently seal and all. I wasn't aiming to keep the seal but it just worked that way. The rear glass i cut the seal and popped it out, managed to drop the front end as well and remove the front calipers. The dash is now out and i am working on the dials and switches etc. The front heater box is a work in progress, and i am starting to remove the head liner from the rear moving forward. I also found the numbers on the dash and a very interesting tag on the drivers pillar on the black windscreen column. the pics are attached.
Attachment 272323
Attachment 272324
Attachment 272325
Attachment 272326
the tag i was talking about before, not sure if this was from the factory or put on by previous owner at some stage
Attachment 272327
5 Attachment(s)
I also found these numbers on the fuel tank, its meant to be a 100L plastic tank I will do some searching and see if i can verify that it is 100L tank. which will be great for long trips
Attachment 272328
Attachment 272329
Attachment 272330
Attachment 272331
Attachment 272332
hopefully this weekend i will get a hand from my brother so the engine and gearbox maybe out soon
So that's a Mustard yellow 2.4E with an oil door and a 100L tank? Sound about the perfect long-distance 911 to me....
Hi Stevie,
Its actually originally a gold 1972 911S, and yes it has the oil door, i am taking it back to gold.
cheers
clayton
Nice! Enjoy the process, it'll be a while ;)
Thanks Stevie yes it will be a bit of a journey but worthwhile i believe.
In regards to the getting the Dash recovered, are there any recommendations of who to send it too ? i am based in Sydney NSW, but i am open to hearing who does the best work, why and where they are located. Any indicative price or costing would also be helpful.
cheers
clayton
Hi Clayton i looked at this recently and after searching the threads got in contact with George at Air Motor Sports george@autoinno.com who quoted $495 for the dash and $295 for the speaker grill. His work looked great (or the guy they sub to?). In the end I went for a new dash from Lakewell.com and although not fitted yet it is beautifully made. There are a few long, long, threads on the registry which basically boil down to only one manufacturer who sells to different outlets, one of these is Lakewell based in Belgium.
Dash Doctor in Melbourne have done two for me @ about $600
