Mine seems to be in the same position as Ed’s….Quote:
My template shows 267 mm from rear most edge of fender, and 95 mm from fender edge at cowl strip.
cm
cm
Realize you have to clear the fuel door cable.
Before drilling make a final test with the antenna base that the mark is in right position, so the antenna will be straight when its folded out.
Best Nick
Fantastic, thank you everyone!
Hi Everyone:
In the process of restoring my 71T and I need your help to determine the correct hole size (in the fender) for a Hirschmann 4900 LS18. The original left fender was replaced with a Porsche factory fender but it doesn’t have the antenna hole.
Best,
Ravi
Ravi
I can give you my existing dimensions , if you did not get info yet
I am just ready to mount mine same model inside the fender panel….
anyone have photo/dimensions of the mount
Thanks for assistance
Frank
Thanks Frank for the offer. I am already passed this task and have already drilled the hole and mounting the antenna.
I ended up using the inside diameter of the aluminum collar to determine the fender hole size. See pic below:
Attachment 573256
Frank,
Here is a picture with the correct factory mount for 69-71 (red X) and the mount for 72+ (Yellow circle):
Attachment 573257
Attachment 573287
Attachment 573288
Ravi
Can you shoot photo of your installation under fender …
So checking the hardware that came for my installation ,looks like this set is not accurate ?
What year is this set correct for ?
Looks like I will need a correct set of hardware …..
anyone want to trade or sell correct set ?
Frank
Frank,
Your PN box is full.
