Another series of MFI questions
Problems outlined below.....
Car starts fine, idles reasonably fine when cold.
Once warmed up and pulling up to a stop idle stays at either 2200rpm (drops to 1400 if you load car a little but more often just dies completely
and playing with the accelerator doesn't keep it going, it just diesbut then restarts fine.
I don't think the distributor advance is the issue as timing has been triple checked and it advances when it should.
Just wondering anyone else suffered the same symptoms.
