Somewhat related, will the oil from the front fender oil cooler drain out when doing an oil change without the engine being at or over 180*
No, cooler and lines don't drain out.
Thanks Ed. After I posted I got to thinking that both inlet and outlet are at the top so the only way to move the oil in the tank is more oil coming in under pressure. So it looks like you will always have a quart or so of old oil mixed in with your new oil. Oh well, I guess that’s what filters are for!
