6 Attachment(s)
FS: @CL - 1972 Porsche 3.0L 911E 'RS Tribute'
Craig's List > los angeles > westside-southbay > for sale > cars & trucks - by owner
1972 Porsche 911E Coupe, Post ID: 7171470536
VIN: -
Engine: -
Trans: -
Color: Chiffon White/Black
Mileage: 48,200 (claimed)
Price: US$76,000
Attachment 530079
Attachment 530080
Attachment 530081
Attachment 530082
Attachment 530083
Attachment 530084
Seller's Description:
1972 911E Sunroof Coupe, 1980s-style Backroads Tourer with many mods and a complete 2019 refresh of most systems.
SUSPENSION/BRAKES: Corner balanced by Tyson Schmidt. Elephant Racing rubber control arm and spring plate bushings in 2019, 3.5 Bilstein strut housings, SC brakes. New ball joints, turbo tie rods, stainless soft brake hoses, caliper seals, new OEM master cylinder, hardware replated. New front & rear wheel bearings. All suspension powdercoated in 80% satin black. Rebuilt calipers. Factory Fuch 7&8-15 polished & repainted alloys.
ENGINE. 1982 SC engine has great mid-range torque but will rev up with ease with the 46mm PMO carbs. Carbs balanced by Tyson Schmidt. Distributor rebuilt and recurved by Aaron Burnham. No pulled head studs. Engine resealed in 2019 by Eurotiks. SSI stainless backdated exhaust. CDI unit rebuilt by Systems Consulting. Flywheel turned. New clutch plate. New clutch cable. New shift linkage bushings.
New: fuel level sender, fuel pump, spark plug wire set, plugs, distributor cap. new distributor rotor. 2 new correct batteries. All new F.I. rated fuel lines. All engine/suspension nuts/bolts/brackets etc. refinished in correct cadmium not zinc.
Only Brad Penn oil during my ownership (10 years).
Compression warm, 1:185 2:184 3:185 4:185 5:187 6:189
Leak down cold: 1: 8%; 6: 3%; 2: 2%; 4: 4%; 3: 5%; 5: 5%
Less than 2,000 miles since above readings using Snap-On equipment.
TRANS: Original 72E 915 gearbox, gear ratios work great with the 3.0 SC engine. Fresh Swepco 201 gear lube. Lightweight flywheel, new clutch plate, CVs greased and resealed in 2019. Trans resealed 2019.
SHIFTER: 1985 Factory Carrera short-shifter with fresh bushings.
BODY/Interior: OEM RS flares added in the 80s. All original pans, fenders, doors, glass, floors, steel bumpers. Original leather door panels and dash fascia, original dash with 1 crack. Original headliner. Recent RS Carpet kit. 1980s aftermarket Recaro seats. Original color was Olive Green, changed to Chiffon White ( a 1980s-only color). Paint is 7/10 with minor scratches and chips. Euro H4 headlights. Fuel tank flushed & sealed.
WHEELS: 1980s Fuchs 7and 8 by 15. Tires are Kumho Ecsta ASX.
This 911 E has always been a California car.
9 Attachment(s)
FS: @Nordic Drive - 1965 (66MY) 911 SWB Historic Racing
Nordic Drive, Jorisvej 19, 2300 Kψbenhavn S, Danmark
1965 (66MY) 2.0L 911 SWB Coupe
VIN: -
Engine: -
Trans: -
Color: Silver Metallic/Black
Mileage: -
Price: 365,000/~US$420,000
Attachment 530270
Attachment 530271
Attachment 530272
Attachment 530273
Attachment 530274
Attachment 530275
Attachment 530276
Attachment 530277
Attachment 530278
Dealer Description:
This is probably the best 911 of this generation. On top of that, its the direct entry to some of the most respected and treasured Historic races that the modern race-world has to offer to this date. This 1965 911 has every approval and homologation needed to fulfill the demands to be accounted in the HTP FIA Class GTS 11 and this is valid until 31st of December 2028.
This 911 is built in 1965 and it was delivered in California on the 11th February 1966.
With the car follows a certificate from Porsche AG dated back to 20th September 2005 that states the origin and authenticity of this vehicle. The car is entirely matching numbers in regards of doors, panels, fenders, engine, gearbox etc.
No major incidents have ever struck this vehicle and every body panel is aligned in the way that it should. close to 400 hours has been spent during 2015/16 disassembling every nut and bolt, repairing and restoring where needed and then assembling and preparing for the new paint job. Since the rebuilt the car has only raced Copenhagen Historic Grand Prix in 2016, 2017, 2018 with Le Mans winner Michael Christensen and in 2019 with Le Mans driver Mikkel Mac.
The current owner bought this 911 from the Porsche racing specialist Roock in Germany in 2015. The car has undergone a complete rebuild with a total cost of more than EUR 250.000.
The engine was entirely rebuilt by Duel Motorsport Dutch Engine Labratories: http://www.duel.nl. This was in 2019 and in direct accordance the all of the applicable regulations. The power of the engine is approximately 200 HP (tested in 2019). The gearbox was rebuild by Porsche Denmark in 2018 to a short ratio unit + new shifter. The car has only been raced once since the engine rebuild this was at the Historic Grand Prix in Copenhagen, where it finished on a 4th place being the highest ranked Porsche at the event.
Further updates and improvements:
New windows (heated front) and the rest in lexan
Bespoke leather interior parts on the door panels and the dashboards
Bespoke wiring for electrical functions including modern dashboard showing all relevant car data and race data
New 110 l fuel tank incl. new fuel pumps + fuel and oil hoses
New sport seats by Recaro with new harness by Schroth Racing
Momo alcantara steering wheel
Updated fire extinguishing system for both cabin and engine
Raceampers by Duel Motorsport
Refurbished original Fuchs rims on Dunlop Racing tires
Refurbished entire brake calibers
Complete roll cage in body color
Lightweight pedals and foot rest by Javex
New rubber trim etc. everywhere
Fire extinguisher (both cabin and enginebay)
Short ratio transmission setup complete setup for Endurance gearbox is included as well (long ratio setup)
Original Porsche car cover
