Looking for a good restorable SWB US passenger side front turn signal lens. Will probably have to consider a complete assembly but only need the lens. Looking for one without cracks or deep pits/sand blasting
Tia
JK
Tia
JK
I have Jim. Will be in your neck of the woods next week. Will send you a PM
Cool! You can have this SWB turn signal assy. The lens is 91% perfect. It would have been 100% perfect if not for the fire. Oh yea, it's a left instead of a right. Doh!!!!!!!!!!!
Bump, still looking for a good original lens or unit
I have removed a bunch of swb signal lenses. I use a die grinder with a pointy rotary file to get the melted tabs small enough to pass throuh the housing, drill the inner end of the rivets and just work the lens loose from the housing adhesive without stressing it too much.
Paul Chappel ( Rooute66kix ) has the passenger side in FOR SALE section.
