69 911 turn signal questions
Not to beat a dead horse with this topic, but I can't seem to figure out why when I put the turn signals on only the rear taillight parking lights come on with the turn signal lights and the headlight switch is in the off position.
I have checked the wiring according to several diagrams available and all of the wiring is brand new and is in the correct location. All grounds are correct and in place, new taillight housings with new bulbs.
Another bit of info is that when the hazard switch is activated none of the parking lights come on as it should, all seem to flash like it normally. When I put the lever to the right position, the turn signal works correctly but the parking lights are illuminated. If I put the lever to the left the signals flash fast and the parking lights come on as well.
Could this be a turn signal switch issue? Has anyone had this similar concern? Thanks for any help. :confused:
