I've refurbished the rear and front suspension on my 71' E. I set the ride height based on the formulas the shop manual gives to set the axle height. I have tripped checked my math and everything seems to be within spec but the height is way to high. I've see folks mentioned measuring the wheel well height. The fender height on mine is 27 1/2" in the front and 26 1/8" in the back. A friend told me I should be closer to 25 1/4" at the front and 25" in the back. If this is the case, how can I be so far off if the axle height is set based on the manual?
Chris
