10 Attachment(s)
FS: @ElevenCars - 1965 FIA 2.0L Coupe
Eleven Cars, Paris, France
1965 Porsche 2.0L 911 Coupe
VIN: -
Engine: -
Trans: -
Color: Golf Blue/Black Leatherette
Mileage: 26,673 km (indicated)
Price: "Upon Request"
Attachment 526338
Attachment 526337
Attachment 526339
Attachment 526340
Attachment 526341
Attachment 526342
Attachment 526343
Attachment 526344
Attachment 526345
Attachment 526346
Dealer Description:
The proposed car was delivered new in France in 1965. It is in race configuration, ready for the 2.0 Cup. It is in a Golf Blue livery / black interior. The car has been fully restored and assembled by Meca Components (Marc de Siebenthal) in Switzerland in 2017/2018. The car has been restored from a bare chassis. It is in perfect condition and working order. The engine develops a little less than 190 hp. The car is ready to race, all safety features are up to date. The PTH is valid (2028). The car has taken part in the 2018 Tour Auto and 3 races of 2.0L Cup, as well as in the Porsche race at Le Mans Classic.
7 Attachment(s)
FS: @Lusti Motors - 1970 911T RSR Tribute
Lusti Motors, San Diego, CA
1970 Porsche 911T Coupe RSR Tribute
VIN: 9110122229
Engine: -
Trans: -
Color: Grand Prix White/Black
Mileage: 30,107 (indicated)
Price: US$84,970
Attachment 526522
Attachment 526523
Attachment 526524
Attachment 526525
Attachment 526526
Attachment 526527
Attachment 526528
Dealer Description:
This 1970 Porsche 911T that is now offered with a clean California title in the seller’s name,was modified during previous ownership as a Carrera RSR 2.8 tribute and was purchased in 2014 by the seller. The car was subsequently built by Tom Martinot / Deutsch Motor Sports of Pleasant Hill, CA, based Upon a 1970 tub that was media blasted prior to welding on steel turbo flares in Grand Prix White w / black trim. Since restoration/ conversion in 1995, top end work (at 11,400 miles & cc'd at 9:1 to run on 91 octane gas), dyno tuning(by Holleran: 261hp / 91ft-Ibs tourue @ the rear wheels) were performed. Drivetrain: 2.8 Engine - Aluminum Case (early '68: 3280343: '67 - 901/ 14-10803) - 2.8 92 mm Mahle Pistons/Cylanders -Twin-Plugged ported 2.7 heads, 2.7 70.4 mm crank& "S" cams - Electromotive Crank-fire Ignition - TWM throttle bodies, "906 maifolds, 3.2 injectors and Halteck EFI (F10) - Carrera oil-fed chain tensioners / Lightened engine mount cross bar -Tildon super starter, SSI heat exchangers & Flow Master Freeflow muffler - front mountted oul cooler w/ steel braided lines & A/N fittings Transmission:915 - Late '72 light weight magnesium case (915/02-7720438) - 7:31 ring/pinion, quaiffe LSD & WEVO Shifter Suspension/Brakes/Electrical - RSR struts w / coilover mount w / Tarett Aluminum billet monoball camber plates - Blestin sport shocks, 22/26 torsion & 22/22 anti-sway bars & front strut brace - '87 Turbo front hubs, front and rear brake calipers & rotors w / cool brake scoops - 944T-8s / 930-9sX16 Fuchs powder painted stain black - Optima Battery in smugglers box w / Rennline mount & cut-off switch Exterior: - Steel Turbo Flares, Fiberglass front/rear RSR bumpers w / oil cooler opening - GTRacing Ducktail w / rubber tie-downs and factory license lights - Crome side mirrors and "Carrera RSR" script - front / rear tiedowns loops & rear towhook / jackplate Interior: - 10k tachometer & large oil pressure light (replacing dash clock) - 380 mm RSR steering wheel - SRD Recaros w / 3 point factory inertia seat belts - OGRacing rollbar and safety harnesses Pictures are available. All service records are availble and under current ownership were performed at "Black Forest" and "Mirage International" of San Diego, Ca. As you can see from this description, this vehicle has been uinquely built and cared for and is ready for immediate delivery.
5 Attachment(s)
FS: @Silverstone Auctions - 1973 911E - 'RS Re-creation'
Silverstone Classic Live Online Auction 2020, July 31 - August 1, 2020
1973 Porsche 911E Coupe 'RS Re-creation', Lot 348
VIN: 9113201049
Engine: (3.0L SC)
Trans: -
Color: Viper Green/Black
Mileage: 11,765 (indicated)
Auction Estimate: £80,000 - £90,000
Sold for: £106,875/~US$140,000
Attachment 529400
Attachment 529401
Attachment 529402
Attachment 529403
Attachment 529404
Auction Description:
- Originally supplied by Malaya Garage, Billinghurst, West Sussex
- Powered by a 3.0-litre SC engine with triple Webers rebuilt by specialist Bob Watson
- Previous competition history and RIAC competition log book
- Superbly presented in Viper Green with the correct 1973 2.7 RS graphics and black interior
- Complete with Porsche Certificate of Authentication
- Inspection of this superbly prepared car and its paperwork is highly recommended
Purchased by our client in 2016, this particular RS re-creation had been built some years previously and used extensively for road rallies etc, however, attention was required and so an in-depth rebuild commenced in March 2018. The vehicle was stripped to a bare shell then shot blasted to ensure that there would be no issues remaining once the build was complete. Utilising all new or fully refurbished panels and parts as required, the re-creation was completed to the very highest of standards and fully detailed throughout. Mechanically, the 3.0-litre engine, which had previously been ‘breathed on’ by well known Porsche mechanic Bob Watson of Bob Watson Engineering, received a full check over and was deemed fit for purpose, the gearbox, however, was found to be in need of attention and was completely rebuilt. Externally the Porsche was refinished in the desirable and instantly recognizable shade of Viper Green and fitted with the correct decals for that nod to originality, while internally a full retrim was commissioned. The project was completed in 2019 and has received little use since.
Accompanied by a detailed schedule of the rebuild (£57,611), rebuild photographs, original handbooks, Malaya Garage Maintenance book, Malaya Garage invoices, and its RIAC Competition Log Book, this RS re-creation comes to market freshly serviced and with a recently issued MOT Certificate ( no advisories) that expires 07/7/2021
This fabulous 911 is based on an original 1973 right-hand drive 2.4E, a valuable car in its own right, and with ‘original’ 2.7 RS Porsches now effectively unobtainable, this superb and highly desirable recreation is offered at a fraction of the cost of the real deal but will provide as much, if not more, enjoyment for its next custodian.
You can now book a one to one appointment (up to one hour) to view this lot at our central location between 16th and 30th July. Please contact us on 01926 691 141 to secure your appointment or charles@silverstoneauctions.com to discuss the car in more detail. The health and safety of both our customers and team remains the utmost priority, we are therefore operating to strict COVID-19 guidelines and full instructions for arrival and inspection protocols will be given when making your appointment.
4 Attachment(s)
FS: @CL - 1973 Porsche 2.7L 911 RS Tribute
craig's list > los angeles > westside-southbay > for sale > cars & trucks - by owner
1973 Porsche 911 RS Tribute, post id: 7166624518
VIN: -
Engine: 6620013
Trans: -
Color: White/Black
Mileage: -
Price: US$105,000
Attachment 529453
Attachment 529454
Attachment 529455
Attachment 529456
Seller's Description:
- 1973 911 with 2.7 MFI RS Engine
- Straight 1973 911 Body
- No Accidents /
- Engine 911/83 MFI
- Fuchs Wheels
- RSR Seats
- Prototipo Steering Wheel
- Sway Bars
- Front RSR Strut Bar
This has been my car for over 12 years. Its been a joy to drive.
10 Attachment(s)
FS: @BaT - 1971 911E Coupe 'RS Tribute'
Bring-a-Trailer Website Auction
1971 Porsche 911E Coupe '2.7L RS Tribute', Lot #34700
VIN: 9111200922
Engine: -
Trans: -
Color: Rubystone Red/Oxford Blue leather with blue and purple tartan accents
Mileage: 87,345 (indicated)
Auction Estimate: -
Sold for: NO SALE (Bid to US$82,500 on 8/4/20)
Attachment 529707
Attachment 529708
Attachment 529709
Attachment 529710
Attachment 529711
Attachment 529712
Attachment 529713
Attachment 529714
Attachment 529715
Attachment 529716
BaT Auction:
This 1971 Porsche 911E was acquired by the current owner in 2018 and subsequently modified in the style of a Carrera RS. The color scheme was designed by Sara Wilson, former Head of Fine Materials at Singer, and the car is now finished in Rubystone Red, and the interior features sport seats and Oxford Blue leather complemented by blue and purple tartan accents. A five-speed Type 901 manual transaxle is mated to a fuel-injected 2.7L flat-six equipped with 911S camshafts, 930 chain tensioners, a reflowed MFI pump and injectors, and a ceramic-coated exhaust system. Other additions include staggered-width Fuchs wheels, Koni dampers, upgraded torsion and sway bars, a vintage-look stereo, Rennline pedals and toe boards, and more detailed in the listing. This 911E is now offered on behalf of the current owner in California with a clean Montana title.
Previously silver, the car has been repainted in two-stage Rubystone Red (82N) with steel RS-style rear flares, fiberglass bumpers, and a fiberglass ducktail spoiler. The seller reports that the front inner fenders, battery boxes, and front slam panel were replaced due to wrinkles in the slam panel and apparent bodywork on the inner fenders, and the car has been fitted with new a windshield and body weatherstripping. A touched-up chip measuring approximately 1/16″ is noted on the passenger fender.
Other modifications include metallic silver rear bumperettes, silver Porsche graphics, H1 headlights, and a single door mirror mounted through the window trim. Refurbished 15″ Fuchs wheels measure 7″ wide up front and 8″ out back, and the car recently received a four-wheel alignment and new Pirelli CN36 tires. A set of 911S front brakes and stainless steel brake hoses are fitted, and the suspension features adjustable Koni dampers, aftermarket sway bars, thicker torsion bars, and Sway-A-Way spring plates.
The seller states that four hides, or approximately 250 square feet, of Oxford Blue leather was used to reupholster the cabin. The material now covers the floors, sills, console, kick panels, map pockets, interior side panels, shift boot, emergency brake boot, and seat adjuster bars. Blue and purple tartan velour covers the sport seat center sections, the rear seats, the door panel inserts, and dash fasica, while the pillars and headliner are trimmed in blue Alcantara and the upper doors and dash are upholstered in contrasting black leather.
The Wilton wool floor mats are the sole pieces of carpet in the interior, and the driver’s heel pad is quilted Oxford Blue leather. A matching piece of Oxford Blue and tartan luggage is included and is secured with leather straps. A vintage-look radio is installed in the factory location and a pair of speakers have been added to the rear side panels. The interior is also equipped with Rennline pedals and toe boards, a custom 917-style wooden shift knob with Rubystone and navy blue stripes, a billet center mirror, and billet lock pulls. A leather-rimmed MOMO Prototipo wheel frames a suite of instrumentation centered around a tachometer with a Rubystone face. Just over 87k miles are shown on the five-digit odometer, a few thousand of which were added by the current owner.
The fuel-injected 2.7L flat-six is based around a 1973 T/V (*653XXXX*) case and was installed using a stainless steel engine mount bar and Wevo engine mounts. The seller reports that the MFI pump and injectors have been rebuilt and reflowed. The engine is equipped 911S camshafts, 930 chain tensioners and locks, 911 Turbo cam covers, Pertronix electronic ignition, a Supertec enrichment cable, an amber fiberglass fan shroud, and a laser-etched lightweight crank pulley. Underhood hardware has been cadmium-plated, and the cooling fan was refurbished.
The engine sound pad and trunk liner are matching quilted Oxford Blue leather, and the underhood and trunk metal surfaces feature Gravitex chipcoat under the Rubystone paintwork. Power is sent to the rear wheels via a five-speed Type 901 manual transaxle and new halfshafts. The brake disc dust shields and other underbody hardware have been cadmium-plated, and the Bursch headers and MFI muffler are finished in a high-temperature ceramic coating. Additional photos of the underside are provided in the gallery and show the floors, suspension components, and more.
5 Attachment(s)
FS: @PCA Classifieds - 1969 911T Coupe - 3.2L/300hp
July 2016 - For sale - US$88,000
PCA Website Classified
1969 Porsche 3.2L 911T Coupe, Ad #44037
VIN: 119120277
Engine: 6195093
Trans: 7190694
Color: Ossi Blue/Black (w/Houndstooth inserts)
Mileage: 74,212 (indicated)
Price: US$89,000
Attachment 529794
Attachment 529795
Attachment 529796
Attachment 529797
Attachment 529798
Ossi Blue, Rust-free, Complete tool kit, jack, air pump, repaint 2019, $70K receipts for paint in original Ossi Blue & mechanical, fully sorted & ready to enjoy, 3.2 liter single plug with 300 HP at flywheel, 915 gearbox with ZF LSD fully rebuilt 2015 with Carrera case, suspension modified/upgraded, Wevo shifter/coupler, Vintage racing seats, new OEM dash period-correct, more detail available. No-contact appt available and PPI welcome. Questions welcome. Photos/video taken on request if there’s something specific you wish to see.
