1 Attachment(s)
HELP!! Need to understand how the '68 license plate harness connects
Friends, I need some help to understand how to correctly re-connect my '68 license plate wiring harness to the main harness. When the rear decklid was removed, they simply hacked the harness at the left hinge. The harness contains a brown wire (which would seem to be ground) and a white wire.
I've checked the main harness near the electrical panel, but I don't see any uncommitted white wires.
I took the picture below from an original '68 at Carlisle. The photo shows the brown/ground wire connected to a ground stud in front of the electrical panel. Does anyone have a photo of the correct electrical connector used for the ground stud, so that I can replicate it as correctly as possible?
Can anyone show/tell me where the white wire connects to the main harness? and perhaps show me the correct fittings to make that happen?
I appreciate the wisdom shared very much. Thank you for whatever contribution you can make.
2 Attachment(s)
License plate light harness
Here's a better picture of the license plate lighting harness, Steve is right, it's a grey wire.
