Pair of NOS Marchal bi-iode Amplilux, H1 yellow bulbs, convex lenses, 188mm OD, $800 + shipping
Nice... You might want to clarify what the application is for these.?
Dave
Thanks Dave,
these can fit early Hella headlight with mods ;-)
Can you say exactly what mods are needed??? E.g., is it a big job to do?
Good question. Inquiring North America needs to know.
Great solution Oliver. I have a similar set in a box tucked away for a number of years, but never hot to working on it.
Seems like you welded the tab for the rubber buffer on the outside of the ring to get enough clearance and the front of the ring is cut round wide enough to clear the lens. But is there enough room left for the other to rubber buffers in the ring and is there enough clearance with the welded tab with the outer bucket?
Are we saying we can still use the front retaining ring as per the originals .?
There had been several discussion about using the larger Citroen DS Bi-Iodes in Hella housings, with all cons and pros, or?
