Help! Aluminium S caliper rebuild - leaking link pipe connections
Hi all,
I have rebuilt my Aluminium S calipers and unfortunately the link pipe connections are now leaking since I rebuit them.
I tightened them up a little more but could not stop the leak and dont want to overtighten the fitting.
Has anyone else experienced this and know how to fix them?
Maybe I should make new link pipes in copper?
If the seat in the aluminum caliper is marked, can this be polished out?
They are correctly built up as LH and RH calipers but I think perhaps I might have swapped the right and left calipers over as the castings are the same when stripped right back. When I rebuilt them the link pipes might now be at the oppostite ends to what they were originally so they are trying to seal where the brake nipples were originally fitted. I am not 100% sure I have done this but maybe it would cause the fittings to leak?
Any help appreciated
Rob
