Looking for RS style bumper trims for a touring style replica, can anyone assist or point me in the right direction?
Cheers James
Cheers James
Stoddards still sold them new as of early this year.
Hi Clyde,
The front is no problem, even at Porsche, but are you sure Stoddards has the rear bumper trim for the RS? NLA at Porsche for a while now.
Cees
Well all I can say is I ordered them and they arrived although I did check the invoice and while I thought it was early this year it turns out to be early last year!!!.
Boy where did that 18 months go.
Part # was 911 505 097 00 and they were not reproductions.
Thanks Clyde,
I will go after it right away, hope I am lucky with Stoddard...
Cheers,
Cees
I just talked with Stoddards and the P/N for the Carrera RS is:
901 505 251 22 (left side)
901 505 252 22 (right side)
They have them in stock. The standard end caps are part 21's.
Gib Bosworth
The PO of my car hand bent/adapted stock narrow body bumper trim for the RS fenders on my car. A little patience and you could most likely do the same, too.
Well it depends on what you call bumper trim.
My version is the alloy trim with rubber insert is the bumper trim and the bright alloy pieces are the bumper end caps.
My part number as mentioned before is the trim number and lettsrollbabe has listed part numbers for the end caps.
There is no right and left for the bumper trim its the same for both sides
