CHUCK.. You forgot a few things!
The Super 90 GT to save weight used thinner glass, had plexiglass side windows with a leather pull up strap (no crank mechanism) they also were delete of undercoating and had vinyl instead of carpets .Plus the speedster seats were aluminum.. In addition they had 60mm GT brakes with air scoops and they normally came with a special trans BBEA + LS..
Push rod GTs very rare cars indeed!
Many people also dont know that They also built 6 pushrod GT Speedsters in 1959 (yes 1959).. I once had one chassis #84912.... and possibly a few with T5 "B" nose panels..And they also built in 1959 29 Carrera (4 Cam)GT Speedsters..
Scooter Gt Seats A The Same Width..
Scooter,
GT seats have always been rumored to be wider but they are the same.
I had a set of aluminum GT seats, the steel GT seats out of my Twin Grille Roadster and the seats out of my Speedster all sitting next to each other.
I measured every dimension of each seat and although they look wider the GT seats are the same. They do look wider and deeper because they are covered with less padding.
And other strange little details about th GT cars is that the inspection covers in front of the steering box are also aluminum and some of the cars were built without the rear shelf behind the back jump seats.
I noticed that this car had cold air boxes and I think that the car should have had the wide alloy velocity stacks not air cleaners on the Solex 40P11 carbs..
Chuck... A S-90 GT for Hannukah?
A S-90 GT for a Hunnukah gift?
Oy Gavoult! Such Hutzpah!:eek:
anybody know the whereabouts of the ex-Ned McDaniel '60 GT ??
seems to me the ex-Ned McDaniel car also had a heated windshield & some other goodies. it was featured in Excellence ca. 1991 shortly before heading to Florida. (~ $200K) this was after Ned won several concours trophies including the 1990 356 Registry West Coast Holiday class win & judges award.
i have those 2 trophies. i supplied the bumpers & some other bits to the restoration. that was the 4-cammer. the sister car (consecutive serial #'s IIRC) was the S-90 & went to the Monterey area in it's unrestored state.
one of those Karl Block '59 pushrod GT Speedsters relocated from the S.F. Bay Area to Oregon about 10 years ago. it was a Fresno area barn find ca. 1984. the owner has turned down some REALLY long numbers on that one :eek:
best
jerry
