Attachment 579227
Found this and a guessing it goes in the engine area.
Any ideas?
Steve
Attachment 579227
Any ideas?
Steve
Looks like it might be the distributor hold down.
999-511-046-03 is the part number for the distributor clamp, but it has a split with a bolt used to set the timing. Maybe this could be a spacer that could be used below the clamp, but the PET does not show any spacer. The large hole is 25mm.
It’s to hook your engine to.
It should be on top of the case near the breather.
Richard
Engine hanger.
Perfect! Glad it was not something that was supposed to be inside the engine. Glen49 that is a pretty engine, what are the holes in the lower valve cover? Maybe to set the cam timing?
Steve
Richard - nice job
