FS: Weber 40 IDTP Carbs
For sale is a set of weber 40 IDTP Carbs that I purchased a few months ago. I am selling as my project has stalled and I want to allocate money elsewhere. Once receiving the carbs I went through them and realized that they, like a lot others, needed help. The floats were crushed and they needed a thorough cleaning. Asking 1900 Shipped in the US + Paypal fees.
One of the air correction shoulders ports was cracked. I sent the body to Paul @ Performance oriented. He corrected the cracked port and did the following:
Weber service
Master rebuild kit
Clean(ultra sonic), re-bush throttle body (using Teflon bearings) and bench flow
throttle valves to be re-used
Supply two, new Weber floats, brass
Supply (4) fuel screens for banjo bolts
Supply two main body stud
Zinc plate intake air horns
I also purchased the correct jets(which are included/installed) for my 2.2T at sea level:
30mm main venturis
130 mains
F26 emulsion tubes
170 air corrections
55 idles
These came with the carbs, would need to be cleaned thoroughly for reuse:
Idle-52
Imul - F1
Main Air - 185(definitely need to replace as they are pretty buggered up)
Vent - 27
Following all of this work being done I assembled one of the carbs. I am an amateur, i recommend you take it down and reassemble to your liking. I also recommend you inspect and possibly replace the nozzles for the accel pumps.
You get everything shown in these photos:
http://img.photobucket.com/albums/v2...pstefwl1fn.jpg
http://img.photobucket.com/albums/v2...psmy4qrom2.jpg
http://img.photobucket.com/albums/v2...pskhfnfm3m.jpg
http://img.photobucket.com/albums/v2...psb2mshaxp.jpg
http://img.photobucket.com/albums/v2...psnddkcy7q.jpg
http://img.photobucket.com/albums/v2...psefxoqdxg.jpg
http://img.photobucket.com/albums/v2...psvbimpnlu.jpg
http://img.photobucket.com/albums/v2...pspxu0yohn.jpg
http://img.photobucket.com/albums/v2...psasvcltp5.jpg
http://img.photobucket.com/albums/v2...psbf5m5faq.jpg
