1 Attachment(s)
1968 911 door pocket reattachment
The front screw that holds my driver's side door pocket to the door panel has come out and won't stay screwed in, I'm guessing the screw hole in the door is threaded. Will I put myself into a pickle if I remove the door panel, attach either a washer and nut or some sort of backing plate for the screw to go into, and then putting everything back together? I've never removed the door panel. Picture of what I'm talking about herein. Thanks!Attachment 528294
