2 Attachment(s)
73 S - engine to oil tank oil line issue..
The original one piece metal and rubber oil line that connects from the back of the engine to the oil tank is NLA from Porsche and has been replaced by TWO lines. While the metal line that runs across the back of the engine terminates in the correct location, the second piece - the rubber hose line with crimped connectors shown in the below photos is about an inch too long. It will connect, but its extra length causes several kinks that can't be eliminated no matter how the connections are turned/swiveled. I am curious to know if anyone has replaced the single line with these replacement pieces and used them successfully. I'm hopeful that ordering another rubber line piece from Porsche might yield one that was cut and assembled correctly to the proper length. My Porsche parts guy researched this today and indeed there seems I have the correct and only part, although too long.
