Not mine...
Wow - I believe the stacks, throttle bodies, and pump are from a 2.2S, but the air cleaner housing might be from a later car. It appears the only thing missing is the mfi fuel pump. Nice find. A good deal if it stays at $600, but I doubt it. Predictions? Probably go for around $1200.
Reserve is not met at $600; I bet it goes for $1200. I'd kill for those linkages and injectors...anyone have any for me? :)
Ken-
Check with Matt Blast at Eurometrix. He sells brand new link ends, and likely other components as well.
$1500+ easily. pump, stacks, anf throttle bodies are worth over $1k as cores.
Thats a pretty complete setup. The little bits and pieces like the fuel lines and pump bracket will nickel and dime you to death when trying to put together as complete a system as that is.
Reserve met at $800...3 days to go.
Yeah - that's me at $800, but I'm out of town when the auction ends :(
I don't think the bid will be even close to holding up as the seller mentioned that he's had lots of interest in the setup.
It'll go on the real 2.2S engine in my 911E if I win it - NO FLIPPING :)
Regards,
Andrew M
Using a sniping site like hammersnipe.com. It'll put a proxy bid for you if you are ever away.Quote:
Originally Posted by andrew15
Sold for $860
Nice deal. There was no way I could have pulled that off for under $1k when I was trying to source those parts. They dont make any of this stuff anymore. Someone got a pretty good deal :)
