1 Attachment(s)
The good news- The fuel gauge is working again.
-I removed the aluminum tube and carefully checked the 3 wires. I discovered the 2 smaller (thinner) wires have small winkles (waves). Almost too small to see, but very evident when carefully running the wires between thumb and finger. I know it came that way because this is the first time its been open.
Hard to see let alone photograph-
Attachment 549518
-I used a round tool shaft to gently/carefully smooth the wrinkles. Seemed to make a difference in the ease of the float going up and down the wires.
-When I attached the tube again, the float didn't move correctly. I gently bent the aluminum tube in tiny increments until the float moved freely.
My conclusions-
-yes the float was getting stuck in the aluminum tube preventing it from freely moving un and down. I might have corrected the problem without taking the sending unit apart, gently bending the tube to create free movement.
- found it very surprising how tiny tube adjustments made the difference.
Good to hear you got it Jeff.
An epilog to all of this: The 914-6 had the same issue, the gauge level indicated 2/3 full and didn't move. Removed the sending unit like so many times before, again laid it gently against a straight-edge (and it checked out straight).
Suddenly I noticed the top of the sendingunfit was not square/level with the aluminum tube, so I simply pulled the top down and "click". I heard the float travel down the tube.
OK, OK moral of the story be sure to check the sending unit's top, to be square with the tube.
Thanks for posting this information
N. Hollywood does not fix these they ask that you replace with new
I like repairing things... thanks
