That is how I interpreted it as well
I am also 100% certain that the rear slam panel on ALL 1973MY cars (and probably for all of the next 2 years cars) was that continuous curve panel
That seems a fair interpretation.
My interest is in establishing factually what shape panel the factory used in 73 on RS and TES since afaik not a different panel. I had an opinion and little doubt but wanted to be sure was supported by credible evidence.
The comments about the BAT example here certainly gave me impetus to look into it today but I’m not that focussed on that listing. After all many RS offered for sale on this thread have had rear slam panel authenticity challenged.
I recognise these photos ( below) are not about the 73 RS; they’re much later cars and US examples but posting them here just to give some comparison. Acknowledgement to Joe Rusz and all other photographers for the images used as evidence
The first is the 1978 911 SC road tested by car and driver in 1978. Note even by then it still has the smooth continuous curve slam panel.
Attachment 613252
The article was published in March 1978
Next is the 78 turbo from a US magazine road test also 78 — unlike the SC it has the more angular kinked rear panel
Attachment 613253
This article appeared in June 78.
Attachment 613349
Attachment 613350
The datapoints are hardly exhaustive evidence and the provenance of the examples is not as clear as the Jenks road test of the RS but seems likely nearly new cars would be supplied to magazine testers like “car and driver” “road and track”So the difference in the panel visible in two articles oubkished about three months apart goves a hypothesis that the slam change happened sometime doing model 78 or perhaps the 930 first?
Finally the 1980 SC also USA magazine test; a naturally aspirated 911 SC has the more angular shaped rear slam panel so it seems that had now been adopted
Attachment 613254
I didn't come across SC engine bay photo from 1979 on quick scan of the www so perhaps the roll-out of the revised panel was completed across all models sooner?
Obviously just three USA datapoints are hardly thorough research but seems in necessary to overrun a “73 Carrera RS for sale” thread with more late 78-80 examples?
In context of model 73 TES and RS authenticity it probably doesn’t matter exactly when the later version of the rear panel was first seen on a 911. Probably “close enough for government work” to confirm (as Hugh had suggested ) it was perhaps 77 or more likely rolled out completely during the model year 78? Roughly five years later than end of the 73 RS production!
Since I have it to hand adding one more image showing the panel on one of the cars used in the RS specific brochure that was put together hastily around end of calendar 72. It is a known early chassis under development so details were not to final spec like the negative script and stickers on the rear panel but still a datapoint as it’s source is clearly the factory known to be taken by a prominent member of the factory when the RS model was brand new:
Attachment 613273
I’m not sensing any arguments or seeing evidence to suggesting that the continuously curved shape is the correct on for the 73 RS*.
Steve
*Hugh mentioned an old thread exits investigating the mysterious square on the panel so I suggest pick-up there if there is any energy or new infomation regarding that point.
This one is real. It is a homologation car as listed.
Purely by chance I looked at the list of cars that were inspected by my aforementioned acquaintance. This is or was HIS personal car. How's that for provenance?
FWIW, the number he was offered the last time we spoke was slightly less than 1/10th the Gooding estimate. Mind you, some time has passed. ;)
Tom
PS: Sold $1,985,000 yesterday
From my observations , I would say that the Duck has been replaced also. This is a later style shell (the fiberglass portion) , I have not been able to nail down exactly when it arrived , but the vast majority of 1973 Production cars seem to have received an earlier version. In fact , I have not been able to 100% authenticate that any 1973 production year cars received them. I have been trying to ascertain this.
0472
Here is an example of an early shell , I have better photo examples but no access now . This will have to suffice.
See any differance ?
RM|Sotheby's Auction, Toronto, Canada, May 31 - June 1, 2024
1973 Porsche 2.7L 911 Carrera RS Touring Sunroof Coupe
VIN: 9113600660
Engine: 6630626
Trans: -
Color: Light Ivory/Black
Mileage: 95,500 (indicated)
Auction Estimate: US$700,000 - $800,000
Sold for: TBD
Attachment 614796
Attachment 614797
Attachment 614798
Attachment 614799
Attachment 614800
Attachment 614801
Attachment 614802
Attachment 614803
Attachment 614804
Attachment 614805
Auction Description:
- Beautifully restored and well-documented with numbers-matching engine
- Exceedingly well-maintained and finished in factory-correct Light Ivory over Black Leatherette
- Accompanied by extensive history file with Porsche Certificate of Authenticity, invoices and photos from a previous restoration, and other documentation, as well as a tool roll
This Carrera RS 2.7 was sold new in Italy and finished, as today, in a subtle and attractive combination of Light Ivory over a Black Leatherette interior (the graphic lower body “Carrera” script so closely associated with this model, however, was added later in the car’s life). It was imported to the United States in 1986 by a resident of Westport, Connecticut. A copy of a document on file indicates that it was titled in Texas at this time.
The very next year, Prescott Kelley, noted RS expert and Porsche Club of America historian, acquired the RS 2.7. Following his ownership, the car would then pass through several collectors before being acquired in 2000 by Roger Hoffmann, a noted collector and frequent Pebble Beach Concours d’Elegance entrant. At some point prior to his acquisition the wheels were painted Viper Green and matching graphics were added to the exterior. Intent on restoring the car to its original glory, Hoffman would commission a two-year, comprehensive cosmetic and mechanical refurbishment sparing no expense, many invoices and photos for which are on file. Hoffman would retain the RS 2.7 for some years and then pass it on to other conscientious caretakers.
Upon entering the Dare to Dream Collection in February of 2014, the car would be serviced to bring it into top operating condition. It remains beautifully presented in factory-correct Light Ivory with period-correct black graphics over Black Leatherette with cord inserts. Notably, the car retains its numbers-matching engine, as confirmed by a Porsche Certificate of Authenticity on file, and it is said to be one of few examples equipped with virtually every factory option, including air conditioning, an electric sunroof, electric windows, a limited slip differential, sport seats, head restraints, retractable seat belts, and an AM/FM radio with automatic antenna. In addition to Porsche documentation and an extensive history file, it is accompanied by a tool roll.
Beautifully restored, incredibly maintained, and perennially lusted-after as the 911 Carrera RS that spawned succeeding generations, this is a stellar and well-documented example that serious marque enthusiasts and collectors will surely clamor over.
Zweck, Miami, FL
VIN: 9113600189
Price: US$625,911
Attachment 615177
`100 photos......and not one to show what it might be under the skin, ie engine bay, numbers etc :confused:
but a lovely closeup of a windscreen washer nozzle :)
Not enough attention is given to the authenticity and provenance of windscreen nozzles Hugh. Think we need a separate thread. Shouldn’t joke there is probably one on that topic here already :)
September 2023 - Cobalt Automobiles, Biarritz, France listed at €550,000/~US$585,150
Bonhams Monaco Sale, Villa La Vigie, Monaco, 10 May 2024
VIN: 9113601031
Engine: 6631009
Trans: -
Color: Grand Prix White (Blue Trim)/Black Leatherette
Mileage: 37,639 km (indicated)
Auction Estimate: US$400,000 - US$480,000/€380,000 - €450,000
Sold for: TBD
Attachment 616227
• Only 3 owners from new
• In France from 1984
• Well maintained since day one
This Porsche 911 Carrera 2.7 RS number 1031 was delivered new in April 1973 to Mr Schultu, in Ratingen, near Düsseldorf. Being one of the 205 Carrera RS sold in Grand Prix White (2222), this example was also equipped with the large 85L fuel tank, sports leather seats, heated rear window, electric windows, Blaupunkt Stereo Player , the ''Carrera RS'' monogram embossed on the ducktail, as well as the spare wheel with folding tire and compressor.
It was in 1984 that #1031, showing 90,000 kilometers, was imported to France by Almeras Frères and acquired by Mr. Gérard Legros. It was then that the “Carrera” lettering and the originally red rims became blue, Mr. Legros’ favorite color. In September 1986, the car passed into the hands of Ruf Automobiles in Pfaffenhausen to receive an update to its running gear as well as its cooling system, while M471 type front and rear bumpers were installed. In August 1987, when the 911 had covered 126,040 kilometers, the engine showed signs of fatigue and the car returned to Ruf to undergo a complete mechanical overhaul carried out by Pierre Ofzky (RS Tuning). It was from Porsche that a Silomine engine crankcase type 911.101.915.00 (compliant with the FIA homologation form of August 1972) was ordered to replace the type 911.101.101/10204 crankcase. The whole thing was reassembled only with new Porsche parts, including 6 high compression pistons, a 2.8 RSR oil pump, hydraulic chain tensioners, a lightweight flywheel and a 2.8 RSR clutch. All of this work is documented in photos and invoices in file #1031. The crankcases were at this time restamped with the original number 6631009.
In the following years, 1031 continued to be maintained and improved by RS Tuning, Sonauto Levallois, Jacques Leprieur and even Raymond Narac.
In the hands of Gérard Legros, #1031 participated in numerous events:
- September 1984: 2nd Porsche Parade Deutschland-Stuttgart
- June 1986: Porsche Meeting in Zolder
- October 1986: 13th Porsche meeting in Monza
- July 1987: Porsche Meeting in Hockenheim
- April 1993: Tour de France Automobile
- May 1993: 20 years of the RS at Magny-Cours
- June 1993: 30 years of the Porsche 911 in Stuttgart
- July 1993: 20 years of the RS at Silverstone
- April 1994: Tour de France Automobile
- April 1996: Tour de France Automobile
- April 1999: Tour de France Automobile
- September 2002: Exhibition at Le Mans Classic
- April 2008: Tour de France Automobile
- October 2008: Exhibition at the Paris Motor Show
Acquired in 2013 by its third and current owner, 1031 was retired from sports and was returned to road specifications. Still regularly used and scrupulously maintained, the RS is today in a good state of conservation but above all, is ready to roll. In 2019, a switch to the power dynamometer was carried out, resulting in 237.7 horsepower at 6074 revolutions per minute. Recently, in November 2023,it received a mechanical overhaul including engine and gearbox removal for complete inspection and replacement of wearing parts.
#1031 will be sold with its French registration document; his Porsche identification card; his FIVA certificate; his FIA passport (expired); his FFSA form (expired); a bench pass sheet; numerous exchanges between Mr. Legros, Alois Ruf, Pierre Ofzky and Jürgen Barth; a service booklet; the 1973 FIA homologation form; the Porsche France homologation form; a file of invoices from 1984 to today and a Carrera RS book by Thomas Gruber autographed by Jürgen Barth.
The car also comes with its spare wheel, its jack, its compressor, its tool kit as well as a set of spare parts.
