http://www.early911sregistry.org/for...hlight=fitting
I have some complete fittings as well...in that place called 'somewhere' :D
YES!! all I need are the Collars. Do you have (4) you can part with?
Call Chuck 5108121140
I am sure I can come up with (4).
PM or email me for details.
If you don't find what you need you can buy new collars from JimmyT on the bird
Attachment 477202
Thanks for the info Jeff. I want to go with the old stuff as the car is completely original.
Chuck
How about this set? The two on the left are for the engine to tank hose and the two on the right are for the cooler to tank hose.
I will PM you the details.
Anyone have a screw-on 90 degree oil line hose end for the larger diameter oil line between the oil tank and the cooler?
Need ASAP. Chuck (510) 812-1140
Does one need a special machine to connect these pieces to tubing?
No, i need the stock fitting at the tank. You have one?
