Thread: Help installation 3 point Repa front seat belts
    Senior Member Nicklasliljegren's Avatar
    Jul 2012
    Stockholm
    I´m having some problem with the installation of my set of front seat belts. I´ve come to a dead end regarding the B post cover. With the bolt running through the cover it seems impossible to tighten the bolt? Whats the trick
    Thanks in advance
    / Nick
    A picture really helps!
    Dec 2011
    Victorville CA
    Heat. Get the rubber hot to eliminate the firmness. I was able to get the wrench in there when it got soft.
    You push the belt up into the cover so it loops out, then you plenty of room for the wrench.
    Jul 2012
    Stockholm
    Ed,
    I think I got the picture. I´ll give it a new try on monday
    Thx
    Nick
    Jul 2012
    Stockholm
    I have finally managed to install the belts. I have tried both techniques. I highly recommend Ed's. The b-post cover is flexible. It was easy to push the belt through the cover. After that, there was plenty of room to tighten the bolt. It was then rather easy to pull back the belt and clip on the b-post cover.
    Thanx
    Nick
