Results 1 to 2 of 2
Thread: Question on front bumper seal installation
    Nov 2006
    S. F. Bay Area
    Having a 'dickens' of a time fitting up the front bumper and a new seal. I have had the front latch panel replaced, and need to know if the small channel that receives the upper, center 'flap' part of the seal is in the correct place. Hope this is understandable. Thanks
    Brian
    S Reg #1032
    #2264 classic's Avatar
    Nov 2004
    Gold Coast.
    Brian, it looks right to me.
    When I fitted up mine, I put in the centre section, without the bumper on, by feeding it in from the side. Then stuck the rest up around the fender, on that little lip.
    From memory I had to make a few little cuts where the profile changes, due to it being bonded together.
    I required the assistance of someone to do up the main bolts of the bumper whilst I lifted the unit to ensure proper contact across the entire bumper.
    Show us with the seal in so we can see where you're stuck.
    Tony
