Results 1 to 7 of 7
Thread: Pressure plate
    #2264 classic's Avatar
    Nov 2004
    Gold Coast.
    Question Pressure plate
    Fitting a new pressure plate to MY69 fitted with a 901/13. The parts manual calls for M8x15mm bolts, and that was what was originally fitted.
    My problem is that when I went to torque them to the factory specks (25 foot Lbs) I felt them "stretch".
    I've since removed them. Is/was there a change to the torque settings?
    Tony
    Where did you come up with that number? I recall (without benefit of a manual at hand) that the spec was more like 18 ft,lbs.
    Senior Member Merv's Avatar
    Jan 2013
    Queensland, Australia
    18.4 ft/lbs or 25 Nm
    Merv
    Member # 2633
    Cars:
    Porsche '68 - 911N (Sold)
    Porsche 356B (T-6) S Coupe
    Porsche 2010 Gen.2 Boxster S
    Nov 2004
    Gold Coast.
    Ed,
    E112 Clutch replacment from the shop manual
    Tony
    Yep, right there, are you using the 10K allen bolts they are showing? Seems to me that the 'normal' hex hd bolt is only 8g rated and more like the 18 ft.lb torgue.
    Nov 2004
    Gold Coast.
    Ed you are correct (slaps forehead) I'm a little jet lagged, and miss read it.
    Tony
    Nov 2004
    Gold Coast.
    Done thankyou gentleman
    Tony
