Thread: radio faceplate recovering question
    Junior Member
    Oct 2013
    Spokane, WA
    I was given a piece of matching vinyl for the face plate of my original Blaupunkt radio for my 73T coupe. Does anyone out there have a good technique for covering the face plate with good results? It seems that if you trim the top and bottom "flush" with the edge and fold the vinyl on the sides, it would fit correctly. I only have one shot at this and don't want to **** it up.
    Thank You,
    Pat
    Senior Member Per Schroeder's Avatar
    Mar 2013
    Avon Lake, Ohio
    That's how I did it on mine. Contact cement on both surfaces and then set it under something heavy to dry. It doesn't seem to tolerate any excess on the top or bottom--won't slide in if it's got any.
    Per Schroeder
    Junior Member
    Oct 2013
    Spokane, WA
    Thanks. Done, I just needed a shove. It came out great. Now if I could just get the radio to work!
    Pat
