Results 1 to 7 of 7
Thread: FS: Engine / fuel tank skid plates - St-Classic
    Sep 2008
    Auckland , New Zealand
    We have been working on these to try and supply an option due to a past suppler doing the vanishing act ,
    Any way Rear skid pan . made as per photo . ali plate 6mm with all stainless brackets and fittings. inc nylon blocks placed in spots to allow better pressure spread if hit (not shown). straight bolt on approx weight 3.85kg's. LWB 69-73 ( will check on a swb soon ) drain holes in place for engine (offset) and gear box.
    complete price shipped to your door by COURIER (only option) $420US (Usa only other countries poa)
    Front pan LWB 69-73 , will fit any std tank (metal or plastic ) straight bolt on at rear , boltholes needed to be drilled for the front . lwt ali with ali brackets . not show is these will have added bead roller ribs .approx weight 1.95kgs
    Complete price shipped to your door by COURIER $346US (USA only , other countries Poa)
    wish i could make these cheaper but the shipping is Huge !!!
    better photos soon showing fitted item
    custom options available
    we will make a run next week if anyone wants to pre order .
    John Gausden
    Auckland, New Zealand
    (shipping carson,CA)
    Early911nz.org
    ST-Classic.com
    ST-Classic Facebook
    Senior Member gregbus's Avatar
    Feb 2011
    Lake Tapps, WA
    You know I'm down for a LWB front pan. As you don't set the shipping prices...it is what it is. PP on its way.
    Greg
    “Whether you think you can, or you think you can't...you're right.” - Henry Ford
    Sep 2008
    Quote Originally Posted by gregbus View Post
    quick read the above post again ;-)
    John Gausden
    Early911nz.org
    ST-Classic.com
    ST-Classic Facebook
    Sep 2008
    update pics on final production item
    John Gausden
    Early911nz.org
    ST-Classic.com
    ST-Classic Facebook
    Senior Member nvr2mny's Avatar
    Mar 2012
    Kansas City
    John, I'll take a set. We must of previously hired the same magician. PM me on pymnt info.
    Sep 2008
    Quote Originally Posted by nvr2mny View Post
    Hello,
    next run in 2 weeks (making them with block orders ) i will put you down for a set and if anyone is interested let me know .
    John Gausden
    Early911nz.org
    ST-Classic.com
    ST-Classic Facebook
    Sep 2008
    Made to order now , 2 week turn around . let me know
    John Gausden
    Early911nz.org
    ST-Classic.com
    ST-Classic Facebook
