Results 1 to 10 of 11
Thread: 1970 911 S Correct painting and radio ?
    Junior Member
    Dec 2013
    Finland
    Question 1970 911 S Correct painting and radio ?
    We do a complete bare metal renovation for a 1970 model (delivered in 11/1969) European 911 2.2. S. Shold
    the engine compartment be black ? I assume so. How is it with front compartment, black or body color ? We are
    doing this car as close to the original specification as possible, thus this is important. The car has been ordered
    with M440, antenna and laudspeaker but without any specified radio. What was the typical radio in these cars in
    1970 ?
    Jul 2011
    Chicago Area
    Radio Info:
    Factory Accessory Folder - January 1970 (MY 1970).
    Philips Auto Casseta AM with tape (M 449)($549.45).
    Blaupunkt Boston (US Band) (M 450)($344.10).
    Blaupunkt Hamburg (M 451)($416.25).
    Blaupunkt Frankfurt ($582.75).
    Blaupunkt Frankfurt (US Band)($582.75).
    Blaupunkt Koln ($815.85).
    Blaupunkt Monte Carlo ($394.05)
    Mike Fitton # 2071
    2018 911S Carrera White
    There are many treads on this theme. Search:-)
    yes, black in engine compartment, over body color, over primer, over shutz spray,(could use primer here also) over bare metal.
    Yes, front luggage compartment is the same. Sometime in 1970/1971, the cars produced at Porsche dropped the semi matt black paint on top of the body color in the luggage compartment and in 1972/73 also in the engine compartment.
    Early 911S Registry #931
    1971 911 2.2T Coupe Tangerine
    Quote Originally Posted by Vekara View Post
    . . . We do a complete bare metal renovation for a 1970 model (delivered in 11/1969) European 911 2.2. S. Should
    the engine compartment be black ? I assume so. How is it with front compartment, black or body color? . . .
    I have a '70 Euro model. The engine compartment appears to be a thin coat of dull black over the car's body-color. The front compartment appears to be a thin coat of body-color --- more over-spray than paint . . .
    HtH
    Quote Originally Posted by Zithlord View Post
    Actually, they stopped at the end of 69. A 70 would have a body color trunk compartment, albeit very thin paint as LongRanger suggests.
    Here is some good reference material of an all original 700 mile 70S: https://www.flickr.com/photos/807244...7630169538658/
    1974 911"S" - Silver
    10 sec 67 VW
    Early "S" Registry #439
    Some interesting details that I have discovered or that friends have pointed out to me:
    (not necessarily limited to 2.2 cars either)
    1) While the bolts and flat washers in most cases are yellow zinc, the lock washers are black oxide (likely due to hydrogen embrittlement)
    2) The bolts holding the rear bumper corners to the body are socket head even though the parts manual identifies them as hex head
    3) Some of the screws holding the front fenders to the body (inside the trunk) were installed prior to paint and some were installed after paint
    Details like this are why it is important to study the photos of original cars. =)
    10 sec 67 VW
    Senior Member Nicklasliljegren's Avatar
    Jul 2012
    Stockholm
    Was not there a difference between Karmann and Porsche? I thought Karmann painted the trunk compartment black and Porsche used body color? But I might be wrong..
    Nick
    Nick, you are correct. Porsche stopped using the black in the front compartment sometime in 1970, while Karman continued using black in the front for approx another year.
    . . . correct. Porsche stopped using the black in the front compartment sometime in 1970, while Karman continued using black in the front for approx another year . . .
    . . . except Karmann never built an 'S'
    Jul 2012
    Stockholm
    I always learn something new here
