Results 1 to 10 of 21
Thread: WTB: Rear engine tin for early '67 911S….
    Nov 2006
    S. F. Bay Area
    I have this, but I need the one that fits this chain case cover.
    Brian
    S Reg #1032
    The sickness continues
    Apr 2014
    San Martin, CA
    i have one and i am local.
    Nov 2006
    S. F. Bay Area
    Trying to reach you by pm….please pm me or bcferrin@yahoo.com. Thanks
    Brian
    S Reg #1032
    Brian,
    If you decide to let go of the tin piece in the pic above, I am interested.
    Thanks,
    Dan
    MBR #2637
    AKA boschdog
    1968 911 Normal Coupe
    Houston, Texas
    Apr 2014
    San Martin, CA
    tin
    it does have some pits on the bottom that will be hidden by the muffler, just wanted to let you know.
    Apr 2014
    San Martin, CA
    Brian,
    I noticed you don't have any fresh sealant on the plug in the chain cover. I would recommend you remove the covers and the chain housings and put a bead of J-B weld around the plugs and the pins in the chain housings that the tensioners mount to, also the pins for the chain rails. Otherwise you will have small leaks.
    KD
