Thread: FS: 68 aluminum 2.0 longblock $4500
    Apr 2010
    Kalimantan <SeaTac<Philly
    Price adjusted to $4000
    i have a 68 2.0 alu longblock for sale. I had bought it from a seller for whom this was not the matching engine for his car. It had been running and even tuned and had valves adjusted 6 months before it was pulled. Compression was good. That was in 2012 and the engine has just sat indoors in a reputable Seattle P-shop since. Advertising as longblock only. no induction or others.
    <<<<< Quoting the original ad:
    Serial number 3280623
    1968 Aluminum case
    901/14 Internal designation
    case stamped 12063
    Good compression across all cylinders
    Just tuned, valves adjusted
    Runs and pulls well
    Engine was apparently rebuilt at some time prior to my purchase, there are signs of new gaskets, etc. case, valve covers, etc. appears to be original and unrestored. No carbs. >>>>
    PIcs of engine before it was pulled
    Dec 2008
    Woodland Hills, CA
    PM Sent.....
    Apr 2010
    Bump up. Up.
    Oct 2008
    Burford, ON, Canada
    Can you post some pix of the serial and build #'s please (in the build # thread would be fine). Other photo documentation would be good also.
    This is the highest build # I currently know of on an aluminum case. I'm sure that less than 40 more could be on an aluminum case.
    Dave
