Thread: FS: 2.2/2.0 Engine Parts
    Senior Member METAVINYL's Avatar
    Mar 2012
    SANTA CRUZ, CA.
    Engine Parts for sale. Basically, everything except the case is listed below. All parts came from the same low miles 1970 911T motor.
    (6) Matched 2.2 or 2.0 911T Heads 901.104.306 Dated 4/69 (3) and 5/69 (3)
    (1) 2.2 or 2.0 Crankshaft Stamped D1 98 956
    (6) Mahle Pistons + Cylinders 84mm Bore
    (6) 2.2 or 2.0 Connecting Rods 901.103.101.0R (2) and 901.103.103.0R (4)
    (2) 2.2 or 2.0 Camshafts 901.105.134.0R Dated 26.9.69 and 10.10.69
    (2) 901.105.111.0R Camshaft Housing
    (1) 901.105.106.1R Cam Chain Tensioner Cover DATED 69
    (1) 901.105.102.1R Timing Chain Housing DATED 69
    (1) 901.105.105.1R Timing Chain Housing DATED 69
    (1) 901.105.101.1R Cam Chain Tensioner Cover DATED 69
    (12) 2.2 Rocker Arms
    (2) 901.105.519.OR Chain Tensioners
    (1) 901 Oil Pump
    (1) Crankcase Breather Cover 901.107.701.2R
    (1) Intermediate Shaft
    (1) Oil Sump w/ Drain Plug
    (2) Timing Chain Gears
    (2) Cam Gears 901 105 545 03
    (2) Valve Covers UPPER 901.105.115.0R
    (2) Valve Covers LOWER 901.105.116.0R
    (2) Chains
    $2000 SHIPPED for everything. I have many photos upon request. Send me a message if you would like to see anything in particular. newoldstock@yahoo.com
    Mar 2012
    SANTA CRUZ, CA.
    More Pictures
    Mar 2012
    SANTA CRUZ, CA.
    I would be willing to sell individual pieces as well. Let me know if you are interested in anything in particular.
    (6) Matched 2.2 or 2.0 911T Heads 901.104.306 Dated 4/69 (3) and 5/69 (3) $800
    (1) 2.2 or 2.0 Crankshaft Stamped D1 98 956 $500
    (6) Mahle Pistons + Cylinders 84mm Bore $800
    (6) 2.2 or 2.0 Connecting Rods 901.103.101.0R (2) and 901.103.103.0R (4) $300
    (2) 2.2 or 2.0 Camshafts 901.105.134.0R Dated 26.9.69 and 10.10.69 $400
    (2) 901.105.111.0R Camshaft Housing $50
    (1) 901.105.106.1R Cam Chain Tensioner Cover DATED 69 $50
    (1) 901.105.102.1R Timing Chain Housing DATED 69 $50
    (1) 901.105.105.1R Timing Chain Housing DATED 69 $50
    (1) 901.105.101.1R Cam Chain Tensioner Cover DATED 69 $50
    (12) 2.2 Rocker Arms $200
    (2) 901.105.519.OR Chain Tensioners $100
    (1) 901 Oil Pump $300
    (1) Crankcase Breather Cover 901.107.701.2R $40
    (1) Intermediate Shaft $100
    (1) Oil Sump w/ Drain Plug $50
    (2) Timing Chain Gears $40
    (2) Cam Gears 901 105 545 03 $50
    (2) Valve Covers UPPER 901.105.115.0R $100
    (2) Valve Covers LOWER 901.105.116.0R $100
    (2) Chains $50
    Please post individual item prices to go along with your lot price...
    Peter Kane
    '72 911S Targa
    Thanks for adding the individual prices...
    Peter Kane
    '72 911S Targa
    Mar 2012
    SANTA CRUZ, CA.
    $2000 shipped for everything listed.
