Results 1 to 8 of 8
Thread: Question on Cad Plating & Best Way to Remove
    Aug 2011
    north of the 49th parallel On Can.
    Need to know if cad plating was the only plating used by suppliers back in day either in gold or silver? on a 1970 built 911 coupe. I was just informed by my plating guy that any parts with cad plating will have to be stripped before he can plate them. What will remove the cad plating without damaging threads. Was Zenith 40 carb hardware cad or? Maybe better to tell me what wasn't cad plated on 70's 911.
    Thanks in advance for any info
    Hopper
    Aug 2009
    SF Bay Area
    Quote Originally Posted by hopper View Post
    Hopper
    Pretty sure that yellow zink was the plating of choice in 70. Cad or zink can be easily removed with fine glass beads and won't do any damage to the metal.
    Jim
    Port Macquarie, Australia
    I'm sure they were zinc too. A weak solution of hydrochloric acid removes zinc - just wait for the fizz to stop and they're done.
    John Forcier
    EarlyS #1987
    Restoration Saga
    Aug 2011
    I thought I read somewhere that the early 911's plated parts were cad plated, if indeed the plated parts were zinc coated then I don't have to remove zinc as my plater said, goody less work as the only way I was thinking of removing the plating was one piece at a time on a brass wire wheel, fun wow, my back was aching just thinking about it.
    Hopper
    Nov 2010
    Glen Allan, Ontario
    From the post below,
    http://www.early911sregistry.org/for...on-911-s/page2
    In particular post #13 by smedley
    "For the LAST time......cadmium plating disappeared with rare exception in the late 50s.
    The plating on late 50s 356s and all 900 cars was zinc, repeat zinc!! This has been reinterated by several 356ers and 911 guys who have consulted platers and metallurgists. Lew Morman, long time PCAer, autocrosser and concour guy....AND metallurgist for Champion Sparkplug set me straight on this back in the 70s.....all of the platers since then that I have worked with in Indianapolis, Chicago, and now Sacramento have confirmed this.
    The plating used on fasteners is an industry/DIN thing not Porsche.
    Later 356s had silver or "clear" zinc. Sometime in the late 60s the industry started using a phosphate wash which coated the zinc yellow/green. We see this transition when Porsche made their supply orders for the 900 cars, and they stated receiving yellow zinc. It is well documented among the 356 crowd that yellow started appearing more on '65 C cars. Conversly, early 900 cars had some left over clear zinc.
    The rare exception? Recaro had all of their slider rails and levers done in real silver cadmium. Again, I had professionals in the business verify this. Those of you who have worked on or dismantled cars know that the rails and levers on these early cars show more corrosion and "chalking out" of the plating......which is why the industry went away from cadmium."
    Mark Smedley
    RG #171
    1971 911 T Non-Sunroof Coupe
    1984 944 Original Owner
    1989 911 Targa
    Any plating guy who can't handle cad (which yours isn't) isn't getting my car. Especially one who thinks my zinc is cad.
    Kenik
    - 1969 911S
    - 1965/66 911
    - S Reg #760
    - RGruppe #389
    It's probably a hazmat thing.
    Sep 2006
    La Quinta
    Hasmat has killed it in San Diego...
    1962 356 Cab, show car, sold.
    Registry #983
    R Gruppe #741
