Results 1 to 8 of 8
Thread: WTB: SWB Drivers side Koni strut
    May 2006
    Riverside CA 92505
    A friend who is not a member is looking for a Koni drivers side strut. Must be the early SWB type. He has a Boge drivers side and a Koni passenger. May also consider a Boge for the passenger side to end up with a matching pair. Insert no important as long as the struts is in restorable condition.
    Feb 2007
    San Diego
    on SWB the driver passenger struts are interchangeable so you are in luck - either side is the same, only the ball joint arm is different (which is not a part of the strut)
    Mar 2006
    Louisville KY
    I have several SWB Koni strut housings if your interested.
    Tony Proasi
    52 split window coupe
    May 2006
    CT
    I can provide a single. PM me for details.
    Tom Butler
    1973 RSR Clone
    1970 911E
    914-6 GT Clone in Progress
    Aug 2009
    SF Bay Area
    Good used one $125.00 plus UPS from Emeryville, Ca.
    Jim
    EASY
    Mar 2006
    Louisville KY
    Jim
    EASY
    Can't beat that price!!! I would at least want enough to buy a worn out ring and pinion
    Tony Proasi
    Feb 2007
    San Diego
    Quote Originally Posted by 911quest View Post
    I just paid $2000 for a worn out ring and pinion, was that too much? I think I can mig weld it and grind it back to spec
    Aug 2009
    SF Bay Area
    Quote Originally Posted by VintageExcellen View Post
    Mark
    I'm sure I can find a "heavily patinaed" one in my junk pile.
    Should I be asking a premium for that one?
    Ciao
    Jim
