Results 1 to 9 of 9
Thread: Service offered: SWB turn signal restoration
    Jun 2003
    Bend, Oregon
    6/16/14 Edit: Thanks for the interest, but I have decided not to offer this service.
    I've restored a number of SWB turn signals in the past and have decided to offer the service on a core exchange basis. As you are probably aware, the supply of correctly marked and colored "Bosch" lenses has been spotty at times. I believe that I have found a reliable supplier for these now.
    The restoration process includes:
    o "Resilvering" of interior of housings - actually copper and nickel plating followed by vapor deposited aluminum and silica layer (same process used on H1 reflectors). Much brighter than the common rattle can treatment.
    o Show quailty rechroming of exterior chrome trim edges
    o New correct lenses installed
    o New correct mounting screws
    o New or refurbished bulb holders
    o New bulbs
    Average cost is $500 per signal, may vary a bit depending on core condition.
    Thanks for doing this John ! Few questions for you:
    o Are you using Marek's lenses ?
    o Since you are offering core exchange I am assuming the wait time is shorter, Yes ?
    o Do you have pics of a sample set you restored recently ?
    Thanks again John !
    Jun 2003
    Bend, Oregon
    Thanks for the inquiry - answers to your questions:
    o My source for lenses is not Marek. I suppose my source could be getting them from the same place in German where he gets them.
    o At this time I will be restoring your cores. I estimate the process will take a couple of months due to the plating and availability of lenses. I'm kicking around the idea of having a few loaner sets on hand that I can send out while the waiting for the restoring ones.
    o Here you go:
    Thanks for asking.
    Jun 2003
    Bend, Oregon
    Few more pictures of some I did about a year ago and sold here:
    I've upped the bar since then as I now have the interior "resilvered" (maybe I should refer to that as re-reflectorized or somesuch).
    Senior Member beetle08's Avatar
    Oct 2010
    Seattle, WA
    John,
    What's your price if I already have my Marek sourced lenses (new and uninstalled)?
    Mauricio
    Three Pedal Posse
    Member # 1935
    1968 Porsche 912-6 TR Tribute
    1968 Porsche 911 L
    1973 VW Sportsbug
    1974 Porsche 911 S
    1991 Porsche 964 Carrera 2 3.8
    "if you see a fork in the road, PICK IT UP!"
    Jun 2003
    Bend, Oregon
    $300 per turn signal including all of the plating if you supply the lenses.
    Oct 2010
    Seattle, WA
    PM sent.
    Cheers,
    Mauricio
    Three Pedal Posse
    Member # 1935
    1968 Porsche 911 L
    1973 VW Sportsbug
    1974 Porsche 911 S
    Nice! PM Sent.
    Early 911S Registry #2990
    Jun 2003
    Bend, Oregon
    I appreciate all of the interest in turn signal (and H1) restoration. I think I've responded to all of the inquiries at this point.
