Results 1 to 9 of 9
Thread: FS: Early 911 Center Lube Parts
    May 2005
    Southern California
    Price $1,000
    If you have plans to build an early and period correct vintage twin-plug race motor, you might want to take a look at these parts (BTW, already refurbished by Ollie's Research & Engineering).
    Early 911 Center Lube Chainbox Covers, Alloy
    Note: These parts were also used in a factory 914-6 GT twin plug race motor along with 906 Center-Lube cams.
    Reference photo only, twin-plugged race motor NOT available for sale.
    I can be reached directly via email at; AJSERRANO at MSN dot COM - No 'pm' please. Thx!~
    THE CAM HOUSINGS ARE NO LONGER AVAILABLVE ~ Early 911 Center Lube Camshaft Housings
    Small 47mm i.d. 3-Journal Bearing Support, Non-Spraybar
    ...3 Journal Bearing Support
    The sickness continues
    Apr 2014
    San Martin, CA
    If someone buys these and needs some NOS cam seals for them, I have a set.
    KD
    May 2005
    Southern California
    Maybe you can post a photo here of your NOS set of center lube seals with a price. Thx KD!
    Apr 2014
    San Martin, CA
    Will do, give me a couple days.
    You should point out that your cam carriers are the correct early versions without the spray bar for the rockers.
    BTW why does that race motor have later cam carriers???
    KD
    May 2005
    Southern California
    Hi KD, that's not one of my engines, I just happened to notice that engine had the same early Solex alloy center lube cam covers I had, didn't pay too much attention. At that time I was more focused on buying the RSR parts he had...
    May 2005
    Southern California
    Weekend bump...
    May 2005
    Southern California
    bump to the top...
    Sep 2009
    UK
    I sent you an email last week. Free bump.!
    May 2005
    Southern California
    Hi Stretch! Happy Holidays!!!! Never got it. try ajserrano AT msn DOT com. Thx!
