Thread: scammer alert od77
    Senior Member moito's Avatar
    May 2013
    AUSTRIA (tu felix)
    scammer alert od77
    just got a typical scammer mail from od77
    Hi, I have the required item(s) as listed and you can let me know if you are in need of others. I can call or txt if you don't mind. What's your phone number? E-mail me on od774138@gmail.com
    Cheers,
    Oscar Davis
    United Kingdom
    Just received similar
    mailtod774138@gmail.com
    This is the message:
    Hi, I'm writing regarding your wanted ad as a good source. Let me know if you are still in the market and a phone number to reach you. E-mail me on bigchriswright@gmail.com
    Cheers,
    Chris Wright
    Blackpool, United Kingdom.
    Cheers,
    Oscar Davis
    United Kingdom
    Member No. 2861
    @p911r on Instagram
    Senior Member CraigF's Avatar
    Jul 2013
    Nashville, TN
    Just received the same e-mail...
    SWB, Nothing better....
    CraigF #2695
    May 2005
    Southern California
    Me too... Adding to this growing PITA and scammer list...
    -----Original Message-----
    From: od77 - Early 911S Registry [mailtod774138@gmail.com]
    Sent: Tuesday, August 12, 2014 1:31 PM
    To: ajserrano at msn dot com
    Subject: WTB: 906 Magnesium Valve Covers - Upper pn 901.105.115.10 / Lower pn 901.105.116.11
    </SPAN>
    This is a message from od77 at Early 911S Registry (
    </SPAN>http://www.early911sregistry.org/forums/forum.php</SPAN></SPAN> ). The Early 911S Registry owners cannot accept any responsibility for the contents of the email.</SPAN>
    To email od77, you can use this online form:
    </SPAN>
    http://www.early911sregistry.org/forums/sendmessage.php?do=mailmember&u=24642</SPAN></SPAN>
    OR, by email:
    </SPAN>
    mailtod774138@gmail.com</SPAN></SPAN>
    This is the message:</SPAN>
    </SPAN>bigchriswright@gmail.com</SPAN></SPAN>
    Cheers,
    </SPAN>
    Chris Wright
    </SPAN>
    </SPAN>
    Well he's now banned from the board...
    But afraid there's not much I can do about the email list he already has..........
    cm
