Thread: ATE Brake Fluid questions...
    May 2011
    Chelsea, Québec
    Trying to find out which is the appropriate fluid to use (now that Blue has disappeared) and where to buy it... it seems it is no longer available in Ontario or Quebec? Any leads appreciated!
    Member #1616
    Feb 2003
    Corpus Christi, Texas
    The ATE TYP200 is exactly the same fluid...minus the blue color.
    Jason Burkett
    Paragon Products
    www.paragon-products.com
    Early 911S Registry #428
    R Gruppe #375
    1973 911S
    1972 911T
    1974 914 Limited Ed. Blk/Yellow
    1989 944 Turbo
    1993 968 Turbo RS
    1967 Shelby GT500
    1968 Shelby GT500 Conv.
    2010 VW GTI, Daily Driver
    Yes, the blue color was just an aid to help visualize the new fluid coming out of the bleeder. Same stuff otherwise.
    Jake
    Early 911S Registry Member #2799
    1973 911S - "Tangerine Tornado" - Two Time SCCA Solo II National Champion (1976 and 1981)
    1967 Corvette Roadster (Black/Black/Black) 4-speed
    I am nearing the point of filling my brake system that includes new lines, master cylinder and rebuilt PMB rebuilt calipers. I have used Castrol LMA GT for years, but if the ATE product is markedly better I'm all in...thoughts please. P.S. this is an entirely stock 73 S that will get only limited street use.
    Unless you're racing and pushing your caliper temperatures way up it simply doesn't matter what you choose, provided it is a quality product. Castrol and ATE are both just fine. I'd pick whatever's cheaper/easier to get.
    jhtaylor
    santa barbara
    If you are not going to drive it much, you'll be flushing more often so use whatever good brand is available.
