Thread: How to install emblem on glove compartment
    Senior Member Nicklasliljegren's Avatar
    Jul 2012
    Stockholm
    I am replacing the missing 911E emblem on the glove compartment. I wanted to check with you guys to see if there is a special process for this as I do not want to harm the emblem or the glove compartment cover. The cover have two holes matching the pins on the back of the emblem. I do not see anything from the back of glove compartment door, so I wonder if the emblem is just pushed and/or glued in place?
    Nick
    Senior Member BrentF's Avatar
    Sep 2012
    Toronto
    I am interested in the answer to this question as well. My '70 911T is missing the emblem on the glove box and there is no sign of any holes where the emblem once was.
    Senior Member moito's Avatar
    May 2013
    AUSTRIA (tu felix)
    the the emblem is joined to the base plate by expanding the end of the two pins ...a permanent joint so to say..but .if you are carefull you can separate the parts. and re-use the emblem...sometimes it works sometimes not
    dont know if porsche changed the methode somewhen at least on some swb i have seen it done this way
    Jul 2012
    Stockholm
    Thanks for the help Moito,
    I also found this thread on the subject
    http://www.early911sregistry.org/for...1s+badge+glove
    / Nick
