Thread: Temp Sender Sealing Washer
    Jun 2003
    Toronto
    What is the correct material for the sealing washer for the temp sender, fibre, aluminum, or copper?
    Rudy
    engine temp sender down by pulley was copper but Alu is ok. Thermo time switch in breather cover was originally fiber.
    aluminum
    900 123 007 30
    A 14 x 18 the "A" means Aluminum (or is that aluminium in YYZ?)
    Jun 2003
    Toronto
    aluminum
    900 123 007 30
    Aluminum it is, thanks all, aluminium across the pond. I meant the switch on the breather cover, so fabric it is, which I thought was correct, just wanted confirmation. Does anyone use a thread sealant on the switch such as Teflon tape before install?
    Jun 2003
    Toronto
    Just thought about the sealant thing, if sealant was used wouldn't it add resistance to the ground path or totally isolate it?
