Results 1 to 8 of 8
Thread: FS: Early 911 Door Latches R & L
    For Sale a set of Early 911 Door Latches with mounting bolts and spacers.
    $47 shipped
    Oct 2009
    Indiana
    i can't tell from the photos, but if nothing is broken, i'll take them. e-mail me at wabsci@aol.com with paypal info.
    May 2011
    Chelsea, Québec
    Oops, missed those: great deal...
    Member #1616
    mshaver51...
    here is a close up of the inside of the left(driver) side....
    you can see the plastic piece inside is worn thru...everything else is fine
    let me know if this still works for you...
    Thanks...John
    Oct 2009
    Indiana
    okay, probably not. thanks.
    ms
    Mar 2006
    Louisville KY
    Mike,
    You can replace the plastic guts they are available separate.
    Tony Proasi
    52 split window coupe
    Oct 2009
    Indiana
    911quest is absolutely right (but i already have a set with rough innards). stephen acworth was interested, anyway. this is a good deal and i doubt that they'll last long. sorry to have caused trouble.
    free bump.
    Aug 2011
    north of the 49th parallel On Can.
    Quote Originally Posted by 911quest View Post
    Mike,
    If they available who's selling them maybe they'll have that special double ended rivet that makes these imposable to rebuild unless your a machinist.
    Hopper
